Can someone tell me where I can find the manifold used with the cycle stop valve installs. It looks to be a 6 way manifold that Tee's off to hold the expansion tank, relief valve, guage, and pressure switch.
Okay, I am going to plumb up my own manifold since they seem to be difficult to find. What it the best way to calibrate the 1Z valve? Do I open up all the faucets and set the pressure that way?
Set the CSV while running about 3 GPM, or one shower by itself. If you have a fairly small tank, the CSV will be set in the middle of the pressure switch setting. ie; 40/60 switch, CSV at 50 PSI. You can call me if you like, and I will talk you through it. 800-652-0207
