I honestly can't remember how to get into the program on that unit. it may be up, x, down, check, or up, check, down, x. sometimes they require you to be at 12:01 am or pm.I dont have a next button. Just up/down, "x" and, "check mark"
In most applications, the water used for regeneration in a twin tank, should not be subtracted from remaining gallons after regeneration.... the Gallons Used for Cleaning ... but needs to be removed from the total gallons per tank.
Something to think about. I know the brine fill is from softened water, but I would think the backwash water would be hard water, and the non-brine flow through the injector/eductor would be hard water, wouldn't it be?The one thing that most if not all over look when it comes to Twin Softeners.......... the Gallons Used for Cleaning....... it is NOT counted by the controls of any system but needs to be removed from the total gallons per tank.
IE......... Cap/Comp hardness = Gallons.... now if the gallons is 1500gallons and by adding up the backwash/brine draw/rapid rinse and brine refill equals 150 gallons then the gallons need to be changed to 1350 or even 1300 gallons.
This will keep the system in balance and soft water 24/7 with no break troughs.
Questions?
It's also on page 5 of this one:And yet at the end of page 10 and start of page 11 of the Fleck/Pantair Manual for the 9000-9100 and 9500 it talks about how to set the meter taking into account the gallons used. For 30 years I have done this and NEVER had challenge with a twin, only challenge I have is when I find that twin was NOT set up with the cleaning gallons removed to the cap..
I agree. 50 gal for regen in a residential application is inconsequential, as most treatment professionals program conservatively because water quality can change (especially well water).I briefly read through this chain and I think some people are overthinking it. My thoughts.
Soft water regen, take away the capacity from the other tank... really? In 95% of applications we program in plenty of fudge factor to accommodate the miniscule amount of water that is used for regeneration. Most companies have been cutting back the cycle times from the old school 10 minute BW and RR to just a few minutes for water conservation. The long term affects on the resin bed is virtually incalculable since in residential applications so little water is even being used. Unless you are programming your system with absolute 100% efficiency and testing your incoming hardness daily, then the couple extra grains you program in to accommodate for seasonal water changes should take care of this usage in most applications. Now in areas where you are sitting at 100 GPG raw water, a backwash could take away some amount of the systems capacity and that likely should be considered in the calculations, or greatly reduce the BW and RR times. Another item that is being missed is that on single tank systems, do we take away the slow rinse and RR capacity from the capacity? We do not typically do this unless we have extremely high hardness. Just something to think about.
