I installed a new well pump and was going to use it to fill a cistern and then pump into the house from there and use a cycle stop valve in the cistern. My plans changed and I will use the cistern for irrigation and not household water. I want to place a CSV in the well just below the pitless. What type of valve would do this. I currently have 2 pressure tanks setup one is 86 gals. and the other is 44 gals. Should I remove one and use it for the irrigation system? If so which tank should I use for the house and which should I use for the irrigation. BTW my cistern will be filled by a different well. My new pump is a 3/4 hp 5 gals min Bettaflow. My well is 480 ft deep in a 6 in. casing so I should have plenty of reserve in the well for normal household use. Correct?
