Mculik5
Planning a bathroom reno and looking at tubs. We have a standard 60" x 30" alcove situation. Going to go with an acrylic tub - probably a Kohler Archer - so as not to have to deal with the weight of cast iron.
I'm a bit concerned about the strength/flexibility of acrylic and have also heard they don't hold heat well (important to me, as I have two young daughters who will be using this tub for the next several years).
Separately, I know most guys set tubs in mortar.
Thinking about all of this, I got an idea.
What if I built a form to enclose the open sides of the tub and then filled the underside of the tub with two-part, closed-cell foam (leaving room for the drain and overflow connections, of course)? Kind of like this - https://www.bertram31.com/proj/tips/foam.htm.
This would stiffen the tub, insulate it, and provide a planar surface to sit on the subfloor. And since the foam would expand up, it wouldn't deform the tub.
Based on my rough calcs, I'd need about $150 in foam, which isn't too bad. And since the foam would be pre-cured, I wouldn't be gluing the tub to the floor and making life miserable for the next guy (probably me in 20 years).
Thoughts? I'm posing this as a hypothetical at this point. Been thinking about it and decided I'd see what everyone else thinks.
Thanks.
Thanks.
