Henry Ramsey
ALL available, code compliant shower valves will be anti-scald, and the least expensive ones will be pressure-balanced. The biggest driving factor in cost is the trim, which can drive the costs up considerable (with often, the same guts).
Asking this sort of a question is sort of like whether you prefer Ford or Chevy...I tend to like Delta and Grohe - Delta is likely more readily repaired, but Grohe parts are available fairly easily, but probably not in as many places without ordering. If you look at the Delta R10000 rough-in valve, you can then decide on any of three different 'guts' to install in it (the guts and trim come as a package, the rough-in valve is a separate item, too, but often packaged together for those sold in say HD or Lowes). If you go that route with Delta, you can get a single handle PB, a PB with volume and temp control, or a thermostatic 'guts' and trim - they all will fit inside the same R10000 rough-in valve. So, you could change your mind a few years down the road, and update the visible and working guts without touching the plumbing. This makes it quite flexible.
After experiencing a Ghrohe thermostatically controlled valve in a hotel in London (the pressure was bouncing all over the place and the temp stayed constant), I chose one for my home remodel and have been happy with its operation. Especially in a shared environment, you'll appreciate the PB functionality, but especially a good thermostatically controlled valve.
I demolished the shower surround myself this morning. The plumber was here this afternoon and he's coming back on Thursday morning to do the rest of the work with the water shut off. I ended up with a single control Moen valve. It's not thermostatic but is pressure balanced and I can live with that.
He's going to install ball-valve shut offs and frame an access panel for them within the closet behind the shower. And install a new tub drain and overflow cover. The cold water pipe is threaded right below the floor beam but he can reach it from above since there is a large gap for the tub drain. The hot water pipe has two elbows making that easier.
Unless something untoward comes up the total cost has come in under $700. I'm not sure if that's high or low but it seems fair enough. Only thing, that's just the plumbing. I have yet to go to the fun stuff: the CBU, kerdi and tile.
Jim, you were the guy who showed me Schluter Kerdi back in 2006 for my other shower and I'm going to use it here
again too. I owe you a thank you for that.
