Converting Shower Stall for Laundry Service
CleanSC
Miami, FL.
Terry, Thank you! One question for you:
When I use the adjacent utility sink (not the one in my drawings, but the one in the garage at a higher level) some water drains out of the horizontal shower drain branch pipe that is shown as abandoned in my diagrams (and 2 feet below grade). Am I correct in thinking that this does NOT need a trap primer then? And I could go ahead and make it a floor drain by just adding a p-trap?
Michael, I use AutoCAD in my everyday job as a draftsman for a structural engineering firm. We don't do plumbing drawings so that's why my diagrams look more like structural sections than real plumbing drawings. ;) So the fittings and such are all drawn by hand.
Cacher, perfect, thanks. That was the detail I knew I needed to confirm. So I need this:
Thanks again, all!
CleanSC
Miami, FL.
Let's Talk About Washer Feed Now
Now that the washer drain is sorted, let's properly feed it.
This is what I have in the wall. Some 1/2" copper feeds with some '71 vintage "hammer arrestors" feeding a Moen shower valve.
How would you fellas convert this to washer hookups? I'm not finishing the walls in here. Do I just sweat on some hose bibs where I like em and that's it? Or (as usual) is there more to this than I think? Is a box required in this case? Can I use those "arrestors" (yea I know) or just cut it all out and get minis?
I'm comfortable working with copper so I have no issues keeping it all the same material.
As usual, thanks for the advice. :)
