Joseph Skoler
On the advice of counsel (that is, the experts here), I'm planning to convert from a pit to pitless well system.
Current pit is a concrete bunker, about 4'x4'x7' deep, with 6" ID steel casing in the middle of the floor coming out about 3" from the floor.
My current thinking is to use a dresser clamp to attach a piece of 6" steel.
I would cut a hole in the steel about 5' below grade to install a pitless adapter.
Would the Boshart PA-100NL adapter be a good choice?
Would the Boshart WCC-A066 well cover be a good choice?
Is this the smartest approach? I know welding would be better, but my welding skills are primitive. I could get things to hold, but I can't be certain of it being waterproof. Plus, if I use a sleeve (larger pipe that extends over both pieces of butted 6" pipe) but the welding of the sleeve onto the existing casing with 1" between concrete and weld would be at best at the top of my skill level.
Thank you.
Here's some pics.
Thank you.
Here's some pics.
