JG307
Apologies if this has been discussed, search engines have a hell of a time with numbers apparently. I'm tying into an existing drain line that is 5" nominal schedule 40/80. I quickly discovered this is a hard-to-find size. I did find some PVC tees of that diameter, but since this is a drain, I'm looking for a wye. I've seen a few online... for $400. That's not happening.
The new pipe (3") is coming in at 90 degrees about 2ft above the old pipe (5") so I have some play with how to approach, but I'm at a loss for fittings. Does anyone have any idea where to find a 5" wye that's not $400? Or is there a way I can make the tee work that I'm just not seeing? How would you proceed?
Thanks,
John
Thanks,
John
