SteveFromMass
- Messages
- 6
- Reaction score
- 0
- Points
- 0
We had the well pump replaced in 98, and has worked flawlessly since then. THe control box says:
8/3/1998
MODEL 2801074915
HP 3/4
VOLTS 230
RPM 3450
Franklin Motor
Just the other day the circuit breaker tripped on the well pump. In turning it back on, it trips again after about 15 seconds or so. When I take the cover off the control box, the breaker does not trip (open circuit).
I am wanting to know if there is a process to troubleshoot which component is at fault, or should I just replace the pump?
8/3/1998
MODEL 2801074915
HP 3/4
VOLTS 230
RPM 3450
Franklin Motor
