wlam08
- Messages
- 9
- Reaction score
- 0
- Points
- 0
I have a very silmilar problem to lancevs in the 11-20 post "tilted iron pipe."
I removed an old toilet about a year ago to have wood floors installed. (yes a year ago - it's a powder room and I 've been re-doing the whole house, so it hasn't been high on the priority list).
I just went install the new toilet and discovered that 1) the cast iron flange is loose (I haven't tried to yank it off yet.) and 2) the 4 inch cast iron pipe is tilted and too high so the back of the flange sits up about 5/8 inch and the fron is about 1/4 inch off the floor.
Initially, I thought it was as simple as pulling the old flange off and installing a 4x3 "push-in" flange (I don't trust myself with lead and oakum), but I tested the toilet fit and it rests on the pipe - not the floor. Not a good fit.
The bigger problem is that the pipe itself sits up above the floor and is flush with the top of the current flange. So, whatever new flange I use, the toilet will never sit on the floor. I don't have access to the pipe below the floor without tearing out some drywall.
I do most things myself and would like to do this without calling a plumber. I don't see any way out of this other than to cut the pipe. The question is, in this situation, where the pipe needs to be flush with the floor, what's the best way to do that? If you really think I should call a plumber, let me know...
Anyhow, I don't think the new floors add any height, so I don't think they've contributed to the problem.
