Mike Mass
New to forum. This is my first post. I have searched and searched the internet for info and I often get directed to this site. I have found very helpful information after reading threads with very similar issues. But I still don't full understand what exactly I should look for. I have exhausted all my searches on this site, I created a log-in and have read the rules of the forum. So with out further ado, here's my issue:
THE PROBLEM:
Pump kicks on at 40 psi (as it should), runs for about 20 secs and clicks off at 45psi. After about 2 - 2.5 mins with NO water running, it kicks on again for about another 15 secs and climbs to 50psi. Another 2 mins of doing nothing it clicks on again and climbs to 55psi. And yet again after a few mins, clicks on and finally achieves 60 psi. At which point it will hold that until I use water and the pressure drops back down to 40 at which point this 4 step "cycle" reoccurs.
THE EQUIPMENT DETAILS:
Pump (according to an old sticker on my original Bladder tank): - 1HP - 230V - 12GPM - 9.80 Amps (I would guess this to be about 15 years old)
Bladder Tank: Well-X-Trol Model # WX-255 (Brand New)
Pressure switch: a 40/60 Square D (Brand new - Just replaced)
No Control Box outside (Just a capped off PVC pipe where the well is)
SOME BACKGROUND:
House built in 1998 - Pump bit the dust for whatever reason in 2005 and was replaced at that time. Now here's an unknown: The pump specs I supplied above I believe is the sticker of the original pump. I am making an assumption that what is in the ground now (since 2005) was the exact same spec'd pump. But unfortunately I can't find any paperwork from when I had that installed.
The Bladder tank, pressure switch, pressure gauge, relief valve, check valve, ball valve, gate valve is all BRAND NEW as of about 1-1/2 months ago (Installed 1/19/2020). Basically I replaced EVERYTHING well related on the basement side for reasons I will gladly get into if you feel it's necessary to explain. But bottom line, at the time of install everything was working fine as far as the "click on and 40 - off at 60" over a nice slow, steady and continuous cycle. I also checked that tank was set at exactly 38psi when empty before installing.
My gut is telling me that the pump might be on it's last legs and is shutting off due to some thermal protection or something of the like. I know pool pumps have such a feature. Do underground well pumps have this too?
I have also read in this forum you guys talking about testing: Ground to hot continuity, Amp readings and some other things. But when I read about you guys discussing these things, it appears most people already know how to perform these tests. If I should be doing these tests I will need a little more Virtual "Hand Holding" - i.e. "Set your Multi Meter to X, touch red lead to Y, touch black lead to Z" etc.
Anyway. Sorry for such a long first post. But trying to provide as much detail as I can.
<Some images attached>
THE PROBLEM:
SOME BACKGROUND:
