Lucky
X marks the spot in the pic that is 2 inches from the joist . this is a 42 x 42 stall. the X is at the 21 x 21 spot. can i use a standard 42 x 42 pan. something like this? newbie trying to determine if it will be relatively easy to drop in a standard pan. i dont wanna work with mud/tile etc. i realize the base has to be leveled with feet or shims or whatever the instructions call for.
also i already cut the drain out at the closest pipe position as i had to lay a temp board on top to continue to pull all the nails from the wall etc. deciding if its worth doing this again as the shower i ripped out or just building a closet. everything is predicated on this pan being ez to do.
https://www.lowes.com/pd/DreamLine-...2-in-W-x-42-in-L-with-Center-Drain/1000463293
