The pumptec was not working if you heard the pump running but no water was coming out. Pumptecs have a hard time working with Dole valves, because the low amps created by the Dole valve are very close to the slightly lower amps that happen when the pump is sucking air. You may need something more sensitive like the Cycle Sensor.
The well manager works like a cistern storage tank with a booster pump, they just don't have to use as large a storage tank because of the way it is controlled. But it is not going to be any better than what you already have.
I think the pumptec is not doing its job, the pump is running dry until the overlaod trips. Then is stays off for a while until the overload re-sets. so the pump is staying off longer than it should, and the cistern is not getting full.
