smokebug
I need to replace the piping from the top of the cap. The piping now is galvanized it has a tee at the top of the cap the tee is resting on the cap no visible nipple under it. It has a plug on top and one end in the well the other to the switch and pressure gauge, there is a nipple and then a union after the tee. The 90 on the cap is loose not leaking just easy to turn. I have tried to open the union but it is tight and it begins to pry on the plastic cap I believe it will break before I get the union loose. My question is if I take the 90 at the top of the cap off will the inner pipe fall. I can post pictures if it would help. Thank you Smokebug
