Steve IAnson
Hi,
I've read quite a lot of different information on bladder tanks / bladderless etc. and have a basic understanding.
My parents have a well in a property in France and a pressure tank with bladder which is only used for filling toilets / watering garden etc.
We are awaiting confirmation but it appears the bladder has ruptured and the pressure is at 0 so when used the pump is constantly going on and off.
They are waiting for the local plumber to return with an air compressor as he's going to test repressurising.
They've been told if it is the bladder, that it is not replaceable and so they'll need a new tank - the same thing happened only a few years back and they were told it's because it's not used for approx 9 months of the year.
Assuming this is the case, until the new pump arrives, is there any reason they can't repressurise the tank and use until the new on arrives? Wouldn't it just act like a bladderless tank where the air would rise to the top and then compress/expand as desired? I understand the air would gradually dissolve into the water so they'd need to keep an eye on the pressure and this would only be to keep them going in the interim, but is there any reason this won't work or they shouldn't do it?
Also as I mentioned, this only happened a couple of years ago: it's a holiday home and for approx 9 months of the year it only has very occasional use which apparently is a large contributor to the cause of the failure.
Does this sound right? The only thing I could find online to back up that theory is mineral/deposit build up on the wall of the bladder making it more rigid and susceptible to splits when later used.
If that is the case then this could start getting very expensive if they keep swapping like-for-like every few years. What would people recommend? A thicker bladder? A bladderless tank that can just be periodically repressurised?
Many thanks
Steve
Many thanks
Steve
