Good day all.
I've been to this site a lot and value everyone's replies.
I'm hoping someone may have a thought on if this would work or not.
We have a 2 story walk-out and this Winter we've had a single water line freeze in a bathroom on the top floor.
The water lines to this bathroom go up an outer wall and and the builder used foam insulation between the outside and the water lines (they say according to code). We can't really see where the line is freezing because we haven't torn apart the wall yet.
At the top floor the one line that freezes does make a turn at the floor height and goes about 5 feet and then up to a sink.
The builder came out to take a look and their final solution to stop the freezing is to branch a heating duct in the unfinished basement over to the wall below the sink 2 stories up. Not actually running duct work up the whole wall to the 2nd story, but just to the wall and into where the insulation is and direct it up.
They say the heat will flow up the inside of the wall and keep the water line from freezing.
I can't say that I'm a fan of this solution and can't seem to find anyone who has a good answer as to if this is a good idea.
My concerns are that the heat would never actually get to the top floor where the line freezes. And they don't know if the line is freezing in the wall where it runs up, or where it runs along the floor and up to the sink. They want to run the heat up to where the line is running along the floor.
I say running along the floor, but I don't know exactly how it is run, if it's up against the wall, or in the wall at that point.
My other concern, is that blowing heat into the wall all winter would introduce a lot of humidity in the wall and can cause mold issues after a period of time.
Any other thoughts/opinions on this?
Thanks so much.
Don.
Thanks so much.
Don.
