Raffiecat
- Messages
- 3
- Reaction score
- 0
- Points
- 0
Hi and thanks in advance for your help. I know N O T H I N G about well and I'm having a problem. I had a stump ground out this morning directly behind the well. Now I have brown water (which I suspect is from the well being disturbed) and fading water pressure. The water is fine from any faucet when I first turn it on, but it fades in about 5 minutes. Could the stump grinding have caused this? Do I need to call a repair person, or is this something that will return to normal with some time. I can see that the thing sticking out of the ground (is that the pump) looks as though it has not been harmed. Just wanted to know if the disturbance around the well could be causing this. I don't want to pay someone to come out here and tell me to wait it out.
The novice housewife thanks you again =-)
Cat
Cat
