DIYChad
Hello,
I am new to the forums, but have benefited from the advice offered here many times. Thanks to all for the time you spend answering questions here.
I recently purchased a 2005-built home and discovered that the upstairs tub/shower has a leak from the drain (would've been nice if the inspector had noticed this, but oh well...) I was able to remove a ceiling trim piece that hid the plumbing and access the underside.
After water started spilling from the downstairs bathroom ceiling (around the trim piece I mentioned) I isolated the source of the leak--the tub drain.
I've done all of the standard fixes at this point--
After a lot of searching online I came across folks mentioning that some fiberglass tubs have defective openings, but I didn't see much in the way of successful "How to deal with this?" information. I removed the drain elbow and discovered that my fiberglass tub is also defective, and the plumber's putty that had been used (I assume in 2005, but I have no idea how many times this has been "fixed") to "correct" the problem failed. There was a lot of putty that I kept scraping out between the gasket under the tub and the bottom of the tub. When I removed the elbow, I could see why! Please see attached photos.
What can I do to correct this problem in a more permanent way? This will be my kids' tub/shower and will see a lot of use. The tub is otherwise fine, no signs of cracks or any other damage, and nothing else is leaking (overflow/shower/inlet valves). I can't get the rubber gasket to make a good seal against this tub bottom.
Thanks to anyone who takes the time to read this and offer thoughts!
Best regards,
-DIYChad
- I replaced the plumber's putty around the drain -- didn't work
- I replaced the drain with a new drain -- didn't work
- I purchased a new rubber gasket to go between the tub and the drain elbow -- didn't work
- I tried drains with gaskets and drains with putty -- didn't work
Best regards,
-DIYChad
