Rossn
Hi,
What a great forum!
I'm near Denver, CO and bought a 1964 split-level home last year. During some demo for a lower level remodel, I've found some efflorescence and that the foundation wall varies from a couple inches above grade to a couple inches below grade. One 20' re-graded section is probably 18" below grade. All but that short section of foundation wall are about 42" high, with 2x4 construction above (to 8'). No sill gasket, maybe 1/8" fiber board with reflective surface behind studs, and then brick veneer
Some areas have minimal efflorescence for 54 years, and some have more. Pulled up the 12 year old conventional carpet and pad, and didn't find any moisture or mold, but the room adjoining the house and garage has some mold beneath 1/2" rubber gym flooring I installed last year. Not sure if that is from the foundation wicking, condensation (room can warm up quickly), or from mopping. Have smelled some mustiness in the main house in one corner, though think that smell may be coming up through a failed cove joint.
The house is set back about 100' (and slightly uphill) from a 1800's unlined irrigation ditch, which runs about 6' deep for 6 weeks during the summer. Top layer soil I've tested is about 60% Sand, 20% Clay, 20% silt and drains well. Prior owners said they've never had any flooding or water issues, though clearly the grade around the house is an issue.
With finishing and insulation in mind, what is my most reasonable option for addressing the potential moisture, when re-grading will be difficult? I imagine some combination of:
- Sealing exterior walls between the footer and slightly above grade with asphalt material or rubberized material
- Exterior drain
- Interior Drain
- Sump pump
Thanks in advance for your input!
Ross
What a great forum!
- Exterior drain
- Interior Drain
- Sump pump
Ross
