I bought a foreclosed home about a year ago that is less then five years old. The previous owner demo'd the tub-shower, but never finished the job. I'm in the process of renovating and had a few questions.
01) In newer homes, could the trap be located further down the line from the fixture drain; perhaps under the slab of the tub? If so, should I install a drain kit to the drain line as seen in "Master Drain"?
Guest Drain Master Drain
I understand every plumbing fixture which drains must have a trap to prevent sewer gases from entering the home. I ask because I assume the guest and master bath tubs were installed similarly (but possibly not). If this is the case however, i'd just have to run a drain kit to the drain line. as seen in "Master Drain". The red pencil in "Guest Drain" is the center of the bathtub drain. Please note the drain line in the guest bathroom is surrounded with soil and the master bathroom drain line is surrounded with concrete. I have not smelled a sewer odor inside the home over the last year.
02) Is it possible to buy the individual components of a faucet assembly or is it more cost effective to purchase an entire new faucet assembly? Like cover plate, handle etc.
Guest Faucet Ass. Master Faucet Ass.
Apologies if "Faucet Assembly" is the wrong term.
What you see in "Guest Faucet Ass." is all that I have for the Guest Bathroom. I suspect the same hardware was used in the master shower. I believe the Master Faucet Ass. is Delta Monitor, but can't pin point the model.
03) Minimum wall depth for a faucet assembly is typically 2-3/4 inches?
I want to thank everyone for their thoughts and wisdom in advance. It is greatly appreciated!
Blow ups below for everyone's convenience.
Guest Drain
Master Drain
Guest Faucet Ass.
Master Faucet Ass.
Guest Drain
Master Drain
Guest Faucet Ass.
Master Faucet Ass.
