Am finishing the basement and I hired a licensed plumber to redo the drain lines for the bathroom. My question is in regards to how he ran the drain lines for the bathroom sink. In the picture you'll see an 1 1/2" stubout followed by a 90 then he used a street 45 into a Wye to connect to the vertical drain/vent pipe. The Wye is 2" and you'll see hes got reducers to connect to the street 45 and vent pipe (theres an AAV in that vent pipe a couple feet above the top of the photo).
From what I understand typically codes say this sort of horizontal to vertical connection in this case needs to be a sanitary tee, not a 45+wye. Is it ok the way this guy did this and if so, why? I'm trying to wrap my head around if for some reason the change in pipe size makes this ok. Not sure if this is up to code, not code but probably ok, or not ok at all and I need to get him out here to fix it. If it is up to code I'm curious as to why, as this seems like an exception to the rule I thought I understood. Trying to imagine why he would run it like this as a sanitary tee seems to me like it would have fit in the same location.
FWIW downstream of what is shown in this picture the 2" pvc meets up with the 4" toilet drain line and then shortly thereafter joins buildings main drain line on it's way out to the street. This is the basement of a 2 family home in New York City.
