Attic Plumbing Cover
Russ13
Louisville,KY
So the wife wanted the shower head to come out of the ceiling and for that to happen it has to go into the attic. It's not a long run(4'-5'). I knew this was going to be a challenge because I didn't want any way for the pipes to freeze if we had a cold winter. So I came up with a box to insulate and protect the PEX plumbing. I used 3/4" ply and custom cut the pieces to fit in between the joist. I used Rockwool insulation inside and out of the boxes. Caulked all the seams, joints, and anywhere I thought the cold could creep inside the box. Also, I noticed, while working on this project, that some mice have had a nice little burrow happening through the insulation. Sometimes you can hear they're moving around during the winter. So it also acts as a protection from them chewing on the PEX. On top of that I have blown insulation covering also. I think this should be sufficient for any freeze and chewing possibilities in the attic space for the shower. I guess if anything happens it will just be a pain to access and replace/move but what the wife wants......the wife wants...;)
Russ13
Louisville,KY
I don't drill trusses.
I do lay insulation of the lines though.
I didn't cut any of the joists. Only the 3/4" hole for the pipe to go through. The boxes were individually placed between the joists and screwed together. Is that what you mean?
index.php
