Are kitchen sink "tailpieces" standard
Edwardh1
South Carolina
we are looking to rennovate moms 1957 home, it has a double side porcelain kitchen sink, the metal pieces (what are they called? its the piece that you would put the stopper into) (Basket) that are where the water drains out at sink bottom where it connects to the undersink plumbing both look really bad and also one leaked (fixed with caulk) . Has a large 5 inch or so thin nut that holds it in place from below and is bedded in caulk from above---
are these pieces standard size ? as in a plumber can fix it or does it become need a new whole sink then whole countertop?
thanks
The common ones for home use are either "1-1/2 inch" or a "1-1/4" OD tailpiece". They come in different lengths and can be cut.
A kitchen sink basket has a 1.5" outlet.
Edwardh1
South Carolina
I was not too clear I am not asking about the size of the pipe that carrys the water away (say 1 14 or 1 1/2) but I am asking about the part that fits and touches the sink itself typically held in by plumbers putty.
It the size of that part standard? i e has not changed since 1957
You are referring to the basket, I think. The putty, if there, is to prevent water leaks-- not to hold the basket in place. There is usually a rubber gasket. The kitchen sink hole is usually 3.5 inches but not always.
A garbage disposal can go there instead.
