American Standard "Clean White Elongated"....
French_guy
Michigan
Hello
How do I replace the fill valve on this model of toilet, without removing the tank?
The nut is lodged into a recessed area, so I don't see how I can remove it easily
Is a special wrench needed? that seems weird.....!
I don't know that toilet. Maybe take a photo with your cellphone of the underside.
Would a deep socket do it?
That sketch looks a bit like a Fluidmaster, but I guess that is unlikely.
But if it were, and OP could replace a seal from the top, that would be nice. Or maybe swap out the whole thing that adjusts higher or lower. Probably too much to hope for.
French_guy
Michigan
You will need to remove the tank for replace the fill valve and supply line for that tank and bowl.
I was able to replace the supply line without taking the tank out. But I can't access the nut
As suggested above, would a deep socket work? Would you know the size actually?
Thanks
