ryanh572
if u understand physics which i can tell you dont then you would understand how this works but you dont. if this is snake oil then why is it saving us 45% on our water bill.
as far as i can tell none of you have bought the valve for the $40 and installed it, so right now your all guessing and none of you have a clue as to how it works. untill you buy one and try it youll never know and if this is all bull then why are there testimonials from all over the us showing the monthly savings??????? answer that
As is well recognized, there are occasional breakdowns, repairs, maintenance procedures, malfunctions, etc., of public water utility facilities and/or other water distribution and supply systems which results in the interruption of water delivery. Such interruptions, while not common, frequently result in air entering the path of fluid flow within the water supply lines. Such interruptive air flow, for purposes of clarity, may hereinafter be referred to as "air pockets" and/or "air flow segments", it being recognized that such air flow may also contain minimal amounts of water such as entrained water vapor. As such, these air pockets are at least partially separated from the conventional water supply passing through the water supply line(s). Regardless of the degree of separation, the formed air pockets or air flow segments also pass through a water meter assemblies associated with the various facilities to which the supply of water is normally delivered. As a result, the homes, businesses and like facilities connected to the water supply lines are charged for water that was never delivered.
In contrast, an air pocket or like air flow segment passing along the water supply line will exert an insufficient amount of air pressure on the sealing structure to displace it from its sealing relation with the inlet. More specifically, the predetermined force or predetermined biasing force exerted on the sealing structure by the biasing assembly from within the interior of the housing is calculated to be greater than any force exerted on the sealing structure from within the water supply line by an air pocket passing along and reaching the inlet of the valve assembly. As a result, the sealing structure will not be displaced from its sealing relation with the inlet and the air pocket will be compressed, resulting in it being disbursed or it being forced into the water in the water supply line being delivered to the facility. As a result air flow will not independently pass through the metering assembly and no inaccurate costs or charges will be registered.
This invention relates to a valve assembly disposed along a path of fluid flow along in a conventional water supply line, upstream of a conventional water meter assembly which is disposed and structured to determine the quantity of water delivered to a corresponding facility. The valve assembly is structured to eliminate or significantly reduce the passage of air through the water meter, wherein the air may be in the form of an "air pocket" existing within the water supply line due to damage, repair, or maintenance thereof. As a result the meter will only register the actual quantity of water delivered to the facility and avoid any charges resulting from the passage of air through the meter.
