Rman
Master mechanic
I had my well drilled 2 1/2 years ago and everything is working great until this morning when I found that there was air bursts in all the water fixtures in the house?!
Info well drilled to 325 feet water at 275 feet 4gpm static at 5 feet. Pump is a 3/4 hp 10 gpm. There's a CSV valve followed by a big blue filter then a water softener.
After running the water through out the house no more air in the water. It's possible that the softener ran last night I was asleep at 2am. Can the softener introduce air during the recharge? Never happened before. Heading into winter what else should I check. Btw there's a check valve 200 feet above the pump as recommended by the well guys in addition to the built in check valve on the pump
Thanks
Thanks
