Mikebarone
DIY Senior Member
I am working at a client’s house where I think I have discovered that the return air duct, (on her five ton split system) is too small for the size of the air handler itself. I also have a good friend that is a licensed HVAC contractor and he agrees that it wasn’t sized sufficiently for the unit. I am going to add another air return to the air handler and see if that is the over-all fix.
I noticed on the tag, to the air handler, that it has been static tested at the factory, at 0.5 inch water column. With the amount of suction the return air duct has now, I know that it would suck the water right out of my water column tester!
My question is…in a perfect world…if the correct duct size was installed, (both in coming return air and out going cool air) what kind of pressure should it have in the air handler in the intake and out going side of the blower motor. Could this pressure be measured in water column inches, as compared to the static test performed at the factory?
I'm also wondering, (before I add this extra return) how much pressure should be at the air handler, so I can size the new return correctly.
Thanks much,
Mike
PS. Any other thoughts on this would be greatly appreciated!
Thanks much,
Mike
