Here is the story and then some questions. Thanks in advance for any help!
My main floor bathroom was periodically clogging and in once case, it overflowed. This is a 20 year old toilet and I think it is the 6+ (maybe 8 or 10) gallon type. The flush is very weak although there is a lot of water in the tank.
Following the overflow, I used a plunger and a closet auger. I don't know that I fixed anything since I had the overflow following my auger work. I also used drain cleaner during this debacle.
I got fed up and felt that this may be due to the older toilet and the weak flushing. I then ripped out the toilet along with the hardwood flooring in preparation for a total overhaul.
Now the questions:
1) The toilet flange is rusted and is a female type flange that is glued around a 3" PVC pipe. What are my best options for replacing this? I see that they make a "male" insert flange that gets inserted inside the 3" pipe which would seem to be an easy option. Considering my clogging problem, is reducing the diameter to under 3" a bad idea? What other options are there other than cutting off the old flange and doing a whole pipe rework? Lastly, is it best that I call a plumber to replace a glued, rusted flange? I do have access to the pipe since I can easily cut out the underlayment since it is exposed.
2) If I do install the flange, they used spacers under the screws that hold the flange to the underlayment since the flange needed to be raised to fit over the hardwood. I will need the same height since I am putting tile in place of hardwood. Are spacers the right approach (metal sleeves that go around the screws) or should I be doing something different?
3) How can I test to see whether I have a real problem with the main drain before I just put a new toilet in place. Originally my thinking was that the problem was more with the toilet but this may be a big oversight. The toilet is out at this point. Should I bring in a plumber to "investigate" and will they really be able to diagnose anything at this point?
Thank you
Now the questions:
Thank you
