MechTech
The vent for the full bathroom is downstream of both the toilet and tub. When the toilet flushes air is pulled in through the tub trap. I've tested using a manometer, and I'm sure it's due to vacuum in the line and not positive pressure. I'd like to install an AAV for the tub, downstream of the trap but before joining the 4" pipe from the toilet. My question is, can the AAV be installed 4" above that drain line, or does it need to be run up through the wall above the water line of the tub?
edit - I've already established that the vent downstream is not plugged/clogged
