I originally thought you were talking about a hot water heater and gave the wrong advice. What you say is confusing in that you say you have pressure but no water in the lines ?????
First of all a well cut in cut out relay even though bought as new can be defective or one that was purchased and tinkered with and returned and resold. Regardless if new or used the relay needs to be checked to the proper cut in, cut out and differential settings once it is properly installed. Assuming your well pump has the ability to pump in excess of 50 psi and there is no external water leaks or use of water at the time of testing the external storage tank has nothing to do with the cut out pressure. If the pump is cycling to often then look at a bad check valve, storage tank bladder issue, or improperly adjusted relay if not defective.
If the water pressure will not build up to the desired 50 psi either the gage, well pump or relay is not operating properly. Start with a new gage, then a known good relay and go from there
Jim, stick with subjects you know something about please.
If the tank pressure is set above cut out pressure the pump will most certainly cycle.
The gauge has nothing to do with the pumps ability to pump up to 50 lbs.
It's not a relay. Relays need a magnetic coil. Pressure switches use a diaphragm.
