i have 1/2" supply to the bathroom.
when installing a mixing valve and controls for a custom shower, do i have to use 1/2" valves or can i use 3/4" valves? should i plumb the 1/2" supply to a 3/4" mixing valve and then use 3/4" pipe for the remainder of the installation?
i guess what i'm asking is this: would the flow be better with 3/4" pipe or am i limited by the 1/2" supply so should i just stick with 1/2" valves?
the other issue is that the kohler valve i'm looking at only comes in 3/4" so should i use 3/4" pipe for the installation or 1/2" and use reducers where needed?
or does it matter at all?
thanks.
pietre.
thanks.
pietre.
