4uzindian
from the last post didnt try to purge air yet. as usual it runs at 30 psi. so i turned auto valve from 10 oclock counterclockwise to 3 oclock. when boiler hand't run for a few hours and pipes where cooled down. turned on thermostat to 70.the pressure went up to 35 psi and it was releasing water from pressure releive valve on boiler it drained 10 ounces of water .when it stopped running pressure went to 30 psi.should.it sitting at 32psi.should i lower the auto releif valve more or is it the expansion tank ?should i have adjusted when it was running or hot .does this matter ?this part 2 of question 30 minutes later !. it turned on an off 3 4 times. there is no drip and pressure is at 31 . if you please .adrees these questions sepertaly so i can understand .
