virtualblues
We live at the bottom of a huge hill. It’s uphill from here in any direction. The Certified Tester that did our Backflow Assembly Test Report last week says our supplied water is, “the highest water pressure in all the county that I've ever tested” at over 145 lbs. Learning of this high pressure coincides with an expensive recent plumbing repair, due to an underground pipe failure between the meter and our pressure reducing valve. Our irrigation system operates at full pressure as it branches off upstream of the pressure reducing valve. No irrigation issues. Home built 2007. The pressure reducing valve keeps the household pressure at 60 lbs. The pressure reducing valve is 18 feet away from the meter. The plumber that repaired the burst pipe (he didn’t know about the 145 lbs. of pressure at the time) now says the pressure reducing valve should be as close as possible to the meter with brass pipe & fittings. I contacted my water provider, Clark Public Utilities, they told me the high water pressure they provide is my problem. I want to ride out the recent repair’s 6-month warranty but be prepared with adequate knowledge for a long term fix should that become necessary. If installing a pressure regulator close to the meter is my solution, can I leave the existing pressure regulator as is? Any helpful advice appreciated.
