Hi,
I'm working on a small 12v project: 90 watt solar panel.
Most of the wire from the panel is 10-12 gauge. However, I might need to use a short section of 16 gauge (maybe 1-2 feet at most) so I can fit the wire through a small hole. Do you think that will that cause a noticeable loss of current or voltage?
The entire run is about 30 feet. Again, it's a 12v battery (with charge controller), the panel is a 90 watt that puts out up to 20ish volts and maybe 6 amps.
Thank you!
Thank you!
