Hey guys, I currently have a 3/4 hp 7gpm 2 wire submersible pump with a wx-203 pressure tank that has a drawdown capacity of 8.6 gallons with a 40/60 pressure setting. The pump is set 300ft down in the well. I'm not sure of static, head pressure, flow rate etc so I'm not even certain it's a possibility.
If I were to replace the existing 7gpm pump with a 10 gpm pump, would that significantly reduce the life of the pump or just mildly?
Not sure if this math is right but since 8.6 is 86% of the recommended 10 gallon capacity for a 1 minute runtime, this should work out to a roughly 52 second pump runtime.
Maybe i could adjust the pressure switch to 38/60 or 40/62 to get a few extra seconds out of it if it's a big deal?
Thanks a lot for your help!
