Question on planning for inspection and floor drain
camerono
Hello folks,
Appreciate any feedback on the following 2 questions:
- I'm currently well into the remodel of my house, and am ready to have the inspectors out to review the soil/below slab plumbing in my basement. I know that I need to plug and fill with water as part of the test, but am curious if I should consider putting a test T inline at the closest point to the exit to the street for simplification of plugging the water for the test?
- I'd also like to put a floor drain in the basement, and assume that the floor drain simply needs a P-trap, and then a bend to vertical (or greater that 45 degrees from horizontal) into the soil pipe (4" ABS) ? Drew a quick image (attached).
Thanks for any advice!
- C.
bitmap drawing, shows P trap below drain line
this may help explain what I think will work. P trap is below main drain line. Connect with a Wye. Turn sideways to view it as up-down.
The drain line already has venting in it, so you don't need to create another vented stack for the floor drain.
David
Thanks for the suggestion ...
This is what I was hoping for, a potential solution. I will check with my inspector ...
Thanks again, geniescience. :)
