View Full Version : Early 90's Crane Toilet Tank
imealsloan
09-28-2006, 11:04 AM
Yesterday the tank on one of my toilets cracked. Obviously it needs to be replaced. However I cannot find the part number anywhere on the tank.
The only identifiers I can find embedded into the tank wall is "1282" and "CR/PL". Neither of these correspond to anything in the Crane catalogue. Simple stuff, but I can't find it. Any advise?
BTW this toilet has "Crane Miser" printed on the bowl, and it's a 2-piece setup. It is NOT an Economiser variation. It's a gravity type from the early 90's.
Verdeboy
09-28-2006, 11:45 AM
It might be best to just replace the toilet at this time. Sometimes a tank can cost almost as much as the whole thing. Also, if there is a Habitat for Humanity Re-store near you, you may get lucky and find your toilet there.
You can try using a special porcelain epoxy if the crack is minor. I've had limited success with that product.
BlueHouse
10-14-2011, 06:44 PM
I agree with Verdeboy. The CraneMiser was a very poor flushing toilet. However, you may be able to fit any 3.5 AS tank on it.
Gary Swart
10-14-2011, 09:12 PM
Any replacement parts would have to be used. Full flow toilets are illegal to sell and no dealer would bother to keep parts in stock especially for a first generation low flow, most of which did not work well at all.
BlueHouse
11-05-2011, 07:03 AM
You could find a 3.5 tank these days.
11-05-2011, 08:41 AM
The CraneMiser was a #3-672 or 6-672 combination witha #3-652 or 653 tank. You do not find it in Crane's catalog because it is no longer produced. IF a replacement tank has the correct "3 critical" dimensions, it should work.
BlueHouse
11-05-2011, 09:33 AM
Are Hymont tanks compatible with CraneMiser bowls?
BlueHouse
11-05-2011, 09:34 AM
Or, could your fit a Gerber Aquasaver tank?
