Dead Badger 5 disposer
Mikey
Hansville, Washington
My neighbor's Badger 5 disposer won't start. When the switch is turned on, it hums, but the rotor won't spin. It is free and spins easily either with the hex wrench or by hand internally. With a new one only $68 we're not going to spend a lot of time on this, but does anyone know how these things start? Capacitor or centrifugal switch? I've heard stories that they can be made to work by whacking them with a hammer, which suggests the switch, but that's an expensive design. The data plate on this says "Model: 5 71" which suggests it might be 35 years old?
As far as I know It is a direct drive motor. Just replace it and don't expect 35 years out of the new one.
Mikey, don't replace it with a Badger 1-1/3 HP unit which I believe you are referring to at $68.00. You are just looking for trouble with moderate usage. You can get 1/2 HP for another 20 bucks. More power=less likelyhood of repair issues in general.
"plumbing supply dot com" won't even sell the Badger 1 because of problems.
I agree that at 100 bucks I wouldnt spend a lot of time on it--I'd just swap it out.
Lowe's carries the 1/3HP Badger 1 for $58. The $68 unit was a 1/2HP Badger 5. HD carries a "Badger 5 Plus", a 5/8HP unit (Google says $69.99, but HD's site doesn't mention it). The Lowe's salesman (who used to be an ISE rep) derided that, saying that Lowe's answer to the 5 Plus was a 3/4HP Badger 7 ($98).
Got the secret code from ISE, so will check on the age tonight. ISE tech support was unable to tell me how these things start, other than "turn on the switch." I'll find out after I rip the old one apart.
FWIW I have the 1/2 HP and Im happy with it but If I had it to do over again I would buy a 5/8 or 3/4 IF it's a 100 bucks. And my usage is pretty lite.
imo a family with moderate usage should have more than 1/2HP. You wont have to worry about someone throwing something really fiberous or gristle in there---because you can get rumble and vibration if the power isn't there.
I've got to hand it to ISE -- they've got one of the most confusing set of product designators I've seen in the recent past. Their Web site appears to have lost (or hidden) the "old" model numbers in favor of their new, quieter named line of fancy disposers. Went to HD and they had one of everything, practically, and no clue about which was what. As for the neighbors, they wanted a Badger 5, they got a Badger 5.
Got a reply from ISE that they use a centrifugal switch for starting their disposers, which explains why sometimes a balky disposer can be started with a smart whack with a hammer.
The neighbor's Badger 5 turns out to be 16 years old.
I think that starting a disposer with a hammer is a great way to keep kids from starting a disposer with their hands down in it. :) Or anyone else for that matter.
The Badger 5 post-mortem autopsy
I picked up new Badger 5 and dropped it off last week. The man of the house decided he could replace it OK, and ultimately did. We took the old one apart yesterday to see what failed (we're both engineers by training). What a mess. The entire insides were rusted everywhere they could rust, also covered with some strange white crystalline stuff, and (of course) full of old rice and beans. The problem was, as suspected, the centrifugal starting switch, which lies at the very bottom of the unit -- it was rusted, corroded, and burnt. Howver, after cleaning the contacts with a point burnishing file, and putting it back together, it started up just fine. It's a tribute to the InSinkErator people, I guess; I would have no qualms recommending them. We gave it a decent burial.
"which explains why sometimes a balky disposer can be started with a smart whack with a hammer."
A road service "mechanic" once "fixed" the starter motor on my truck with a 3# hammer. It lasted until I replaced it a couple of days later.
Installing the Evolution in the Seattle area.
Only a couple of days! I put off getting a new starter for almost a year by smacking it around and roll starting my old Toyota. I Was broke then, so I had no choice.
My first new car was a Citroen ID19. After about 4-years, the starter would stop at a dead spot. Dropping the transmission in 4th and rocking it a little would move it enough so it would start. I sold it to a guy on post before I transferred to Korea. Always wondered how that car faired after selling it.
