View Full Version : Stripping Cabinets
dstpshort
01-24-2006, 09:16 AM
Our home was flooded and we had to buy new lower cabinets for the kitchen. We thought they were oak and purchased the "exact" oak cabinets from a surplus warehouse (no returning them). I've tried about 10 different kinds of stain to match the top and bottom cabinets and have had no luck. The base tint of the top cabinets is yellow and the base tint in all the stains I've tested are red. Is there any way that I can strip the upper cabinets to stain them all the same? I really only want to poly them to bring out the natural finish of the oak.
Cass
01-24-2006, 09:29 AM
Your loking to do way to much work and the paint may be in the grain of the painted wood. What brand of stains are you looking at. I thought Min Wax had a yellow based oak stain.
Bob NH
01-24-2006, 10:05 AM
I have found that 5f5 paint remover is effective. It contains methylene chloride and is not to be confused with the one labeled 5f5 Eco Solve with which I have no experience.
Your job will be easier it you remove the doors to work on them.
If you have occasion to sand the surface after stripping you must be VERY CAREFUL around the edges of the veneered parts. If you let the sander go over the edge it will almost instantly go through all of the veneer down to the underlying core and be very apparent when you finish the part.
I find that the little "palm sanders" are very good. They use very small high speed random strokes and don't require any concern about direction relative to the grain of the wood. I have a Black and Decker model sold by WalMart and probably others that has its own little dust collector.
You need to use very fine paper and I would try to use 220 grit or finer aluminum oxide on the raw wood. I have found that powdered pumice with a multilayer pad of paper towel on the sander does a nice job if you want to polish the polyurethane finish between coats to get rid of the little blemishes, or after the final coat. You need to wipe the surface clean of particles before the next coat. I use Coleman fuel as a mineral spirit for cleaning up.
