ario
12-03-2005, 01:16 PM
The original plumbing was done in 1922. It's a cast iron flange set in a bed of mortar on top of pine flooring; 14" offset. I installed 3/4 plywood and then tile. Now the flange sits 1/4" below the surface in the front and 3/8" below the surface in the rear. A local plumber wanted $900 to tear it out and redo properly in PVC. I would like to use a spacer of some kind if possible? I know there are PVC spacers, but shouldn't I use some kind of gasket? Is there going to be an issue with the tilt of the flange? How much of a spacer do I need? Thanks in advance!!
http://img228.imageshack.us/img228/1048/flange1xn.jpg (http://imageshack.us)
