Khayes
I know this is pretty basic. I have 2 new vanities with undermount sinks. The sinks are Kohler with the drain holes in the middle of the basins. The problem I have is the pop-up linkage is not long enough to reach the pull-up rod in the faucet. How do you handle this? All the older sinks I've seen had the drain hole located toward the back of the sink, but now that they are in the middle, the rods are too short.
One more question (maybe should be a new topic?)...on a Moen shower valve, is it possible to change the finish from brass to oil rubbed bronze with a trim kit or will I have to install a whole new valve?
Thanks for any help.
