jgold47
Forgive my sort of goofy explanation of what I am trying to do.
1. house was built in the 20's. Has been updated several times, but unsure of the age of the plumbing in the main bathroom.
2. Tub/Shower has a) two valves H/C for just the shower b) 2 valves and a waste valve for just the tub. these are on the 'wall'. the waste valve no longer affects the drain (just bangs inside the wall).
3. Tub has a small spout, mounted where you normally would see an overflow valve.
here is my quandry. I want to open the wall to install a thermostatic valve (the exisiting ones are starting to leak, the hot water one you have to turn open, then pull out to turn on). That seems simple enough. however, if I wanted to retrofit the rest of the tub, with a more modern drain/stopper assemby, as well as a more modern spigot and remove all of the existing separate 'tub' plumbing, what am I likely to run into in trying this and how hard is it likly going to be to get at the drain assemby from inside the wall? I cant get at this from the back, nor from the floor, but I can open the wall all the way up to the top of the tub.
Thoughts?
PS - forgive my ignorance, but if I wanted to install a second valve on the opposite wall and have a dual head shower, generally speaking using 1/2 supply lines, would i have enough juice to make this work?
Thoughts?
