Shower arm extension?
DaveNJ
NJ
Hi, I need to lower the showerhead in my Mom's shower - do they make extensions for shower arms - say, 6" or so?
Jc60618
DIY Junior Member
Chicago
You can install a hand held attachment with a side bar. The slide bar assembly can be installed to what ever height you want.
DaveNJ
NJ
Thanks, that's definitely an option, but I was just looking for a "quicker" fix. If they don't make them, I'll put one of those up.
Jc60618
DIY Junior Member
Chicago
Google up shower head extensions. Extensions are made put you might have to go to a plumbing supply house or a bath show room.
Asktom
Victor, MT
You could remove the shower arm, screw it into a 1/2" chrome plated 90 degree elbow and, using the correct length nipple, hook it up where the arm used to be. The shower arm will then drop down parallel to the wall and sweep out away from it at the bottom.
Jimbo
San Diego, CA
It doesn't get much easier than a slide bar unit. They can be attached to the wall with double stick, and you almost don't even need a wrench to make the hook up. They are also very convenient for all concerned. Whoever has to clean the shower will like the availability of the handheld, and if mom ever has need to be using a shower chair, the slide bar and and hand held are very convenient/.
The two ends of a shower arm are different lengths. If you buy a 6", 8", or 10" shower arm and screw the shorter end into the wall, the other end will lower the shower head to whatever dimension you purchased.
Agu
Tampa, FL
I'm 5'11" and the Mrs is 5' nothing. There are multiple showerhead kits that allow adjustment of showerhead heights with out doing more than replacing the existing showerhead with an adjustable showerhead.
DaveNJ
NJ
Hey all, I just found this, which I would think will do what I need (it's been hard to find one in BN):
DaveNJ
NJ
Actually, scratch that - it's not threaded...
But, this is pretty much what I need. I don't know if I'll have the proper clearance if I were to buy a 10" or 12" arm and put the short end into the wall since the ceiling is relatively low and the shower line is pretty high already - I'll have to measure it...
There are hinged shower arms which allow you to postion the head at any elevation you want. If you get one, be sure it has "teeth" to hold the position. The ones that use friction are almost impossible to tighten enough to keep the head from "sagging".
if it has teeth, you will usually see them where the two pieces rotate. As as sidebar, I have made BN finishes by rubbing a chrome piece with a steel wool pad or open grit sand cloth.
