View Full Version : Mortar Glass Block Shower
bighornram
10-14-2009, 08:50 AM
I'm enclosing a corner shower construction with a glass block wall. The wall has 2 angles which will cause the outside mortar joint to be a couple inches across the outside edge of the wall. Is this acceptable to have a big mortar joint like this? Documentation states to make mortar joints 1/4 which I am doing on the straight runs but these corners have the bigger gap. :rolleyes:
10-14-2009, 09:48 AM
Doesn't the glass block come in angle pieces, or is your angle an unusual one?
jadnashua
10-14-2009, 10:32 AM
Many suppliers of glass block have both outside and inside corner blocks...you really want one of those to make it look neat and reliable. A huge expanse of mortar would not look good and focus your eye on it. It would also be likely to crack.
bighornram
10-14-2009, 12:40 PM
I have just returned from my hunt for the corner blocks. I <can> special order them. I am going to mortar the corner, and inlay tile. I'm hoping the tile which I will cut from the stock I'm using on the walls and floor for the shower will "accent" the glass.
jadnashua
10-14-2009, 01:14 PM
My guess is that will look better than a big expanse of mortar, but will still look like a kludge. Good luck, as once it's up, you won't want to tear it down to put in the corner blocks. I'd consider mocking up a section...you could probably use some tape and stack the blocks with the tile inlay...see what you and the better half think. You could probably stack them in a room's corner to provide support and emulate the shower wall (without the light from behind). The corner blocks are likely a lot more money than the straight ones, but probably worth it.
bighornram
10-15-2009, 12:52 PM
Point well taken. I am a perfectionist and I would forever look at those tiles and think I should have done it the "right" way.
10-16-2009, 08:05 AM
It is not so much that YOU are a perfectionist, as whether some buyer for the house in the future was a perfectionist and would wonder, "Who in the world did THAT?"
bighornram
10-16-2009, 10:10 AM
Thanks for the "focus". That is why I put this post up,
johnfrwhipple
10-16-2009, 09:38 PM
Do they make the right angle for your Job?
If you are filling in the large void you are going to see some or alot of cracking through the block into that void.
make sure if you go that route you fill in those voids with diamond lath, and the vertical mini rebar lengths. I might pick up some white tile and cut fill strips first leaving them back 5/8 from the finished edge then fiber tape it and set your accent tile. You need full coverage of White Glass block mortar between the glass blocks but I might say that outside corner you will want to set with Granny Rapid White.
