I recently noticed my toilet running and decided to try to fix it. I first looked to see if any water was draining into the bowl and that was not the case so then I decided to search around the internet and found out I probably needed to replace the ballcock fill valve discs that are right inside the cap. So I bought a few from a local plumbing store and replaced them, however now the problem I have is different and this is happening on 2 of my Mansfield toilets.
This is what happens ..
I flush the toilet and the water begins to rise. It rises up just before the top of the flush valve and then when the ball gets high enough it forces fill valve to shut. Then within 5 or so seconds it releases and then you hear a water running noise for about a second. It gets quiet and then in another 5 seconds it releases. By this time the water is moving a little bit making the ball move up and down causing it to almost continuously release and refill. After about 10 times it finally stops doing it.
I have tried putting everything back together countless times. Tried adjusting the water valve so it doesn't fill up as fast too. I also tried turning over the fill valve seal in the ballcock.
please help... this is taking me forever
