View Full Version : Pouring concrete around/over yard cleanout drain
mba79
08-04-2008, 08:11 PM
I'm having concrete poured around my side/backyard and trying to figure out the best way to deal with what I assume is a cleanout drain in the dirt. Attached is a picture of the actual drain which is 7" wide by my measurements. The drain itself is roughly 5"-6" lower then where the concrete will eventually be poured up to. Looking for an aesthetically pleasing cover (and box to be poured around). I'd rather not go through the hassle of extending the pipe if I can avoid it.
The local hardware stores sent me to a pre-cast concrete place but the smallest thing they had seems a little big for my need. I only bought it because the mud was being poured today, but they cancelled and I want to make sure I get the right thing for this. Any advice would be greatly appreciated, hope this isn't a double post but I couldn't find anything like this anywhere online.
Thanks Mike
Redwood
08-04-2008, 08:19 PM
Try an irrigation box!
mba79
08-04-2008, 09:07 PM
That would work? I would prefer a cast iron or stainless steel cover in all honesty. If there isnt anything else or a smaller version then do you think what i have will work? Thanks again.
Redwood
08-04-2008, 09:25 PM
What is this concrete? A driveway? Sidewalk? Patio?
mba79
08-04-2008, 09:39 PM
patio...light traffic
Redwood
08-04-2008, 09:45 PM
I've used the irrigation boxes in that application with good results. Just make sure its a good beefy one. You could use what you have too. The thing is you either have to be able to get a wrench on the cleanout to remove it or, get a different type of cap where a tool that extends down into the cleanout can be used. Typically these have a slot or a square hole.
