View Full Version : Toto Aqua, sanitiser for the tank?
tjbaudio
07-14-2008, 03:17 PM
We have had the aqua for over 6 months and we really like it so far. When installing it I noticed a sticker on the tank lid that says to not use chlorine based tank sanitizers as it can damage the valve. What tank sanitizer is safe to use? I want some thing that fully dissolves over time so I don't have to take some plastic bit back out or residue to clean up.
Gary Swart
07-14-2008, 05:20 PM
The water in the tank of a toilet (NOT the bowl) is clean tap water. It changes every time you flush so it stays fresh. In an emergency, you can even drink it. There is no way water or anything else from the bowl can get into the tank. Point is, it doesn't need sanitizing. Bowl cleaners that are placed in the tank are harmful to the innards of the tank and should not be used.
Redwood
07-14-2008, 05:44 PM
Check out the Fluidmaster Flush n Sparkle bowl cleaning system.
It is a system that is mounted in the tank, but, is applied directly down the overflow tube into the bowl bypassing the components that may be damaged.
Gary Swart
07-14-2008, 06:04 PM
Note that the product Redwood recommends is a bowl cleaner, not a tank sanitizer.
Redwood
07-14-2008, 06:37 PM
I didn't say I recommend it!
In our house we clean toiets and use nothing!
However, If someone is compelled to use these items this hopefully will prevent someone from using a product that damages all the rubber parts in the tank.
My Dogs and Cats like to drink that cool fresh water in the bowl...
Changed many times a day!:cool:
tjbaudio
07-15-2008, 03:37 PM
Well my wife is slightly disabled and we are both very busy people. The toilet starts to have a slight oder if not cleaned every week. What we are looking for is more of an auto cleaner for the bowl. I always thought they were called tank sanitizers. I know the real solution is to clean more often. However a little help is nice.
As for the pets we keep the lid down and give them fresh water.:D
I will check out the sparkle system.
Gary Swart
07-17-2008, 06:28 AM
I would suggest a bowl cleaning product and a brush. A squirt or two of the cleaner and swish around with the brush and you're good to go for another week unless there is streaking that might require another application.
