Home made P-Trap
rmateyko
I have a problem - see related post "How many elbows". I need to raise a p-trap in a joist bay in a basement where I am building a bathroom so that i can drywall the ceiling. The p-trap comes off a bathtub in the bathroom directly above.
If i raise the p-trap I need to cut a hole just above the existing p-trap hole which will mean i have two holes each 2 inches in diameter in a 7 inch deep joist in very close proximity - not good.
Is it possible for me to construct my own p-trap using elbows and a piece of drain pipe. So instead of it being a "j" like shape it ends up being a "u" type shape. That way I can stick the horizontal part through the existing joist hole and connect to the bathtub on one side and the rest of the drain system on the other side.
the problem I am having with standard type plastic p-traps you buy at home depot is that the trap weir ( if that is what you call it) creates a fixed offset. to move the bottom of the p-trap up i have to cut the hole higher.
I have included some drawings
thanks ahead of time
roman
Leejosepho
DIY scratch-pad engineer
www.nonameyet.org
I *think* I remember "back in the day" when there was no such thing as a ready-packaged trap and *everybody* had to construct their own. A "j" is really nothing but a "u" with one side extended, so yes, I believe what you are considering should work just fine as long as all of the "u" is actually there.
You can't (or shouldn't anyways) make the drain path go up from the output of the p-trap's normal outlet...from the outlet of the p-trap, it should always go down so gravity can do its thing. Failure to follow that rule will lead to slow drains and clogs of hair, etc.
Jastori
Illinois
From the side (horizontal) view, you want to duplicate the rise and fall of the "store bought" p-trap. That is, there should only be one "trap", and the drain should have a downhill slope immediately after the trap, all the way to the stack. The total depth of the trap does not need to be exactly the same as the store bought, but you would want it as close as possible.
From the top view, extra bends in the path of the trap and drain should not effect the function of the trap, so long as they are gentle sweeps, and as few as possible.
Hope that helps...
Kevin71246
Chicago burbs
Can anyone point to any references on code specs for a p trap? From time to time I have to make one as well, to go around a floor joist for a bath tub, etc. I happen to be in a Chicago suburb that uses Illinois plumbing code. I couldnt find anything. See attached for what I'm looking for. Thank!!
IPC Traps: ftp://www.ilga.gov/jcar/admincode/077/077008900D04100R.html
https://terrylove.com/forums/index.php?threads/shower-trap-out-of-three-90-degree-ells.54100/ is not the code reference you seek, but you might find it of interest.
WorthFlorida
Solutions
Orlando, Florida
....If i raise the p-trap I need to cut a hole just above the existing p-trap hole which will mean i have two holes each 2 inches in diameter in a 7 inch deep joist in very close proximity - not good.
If you have room, sister in a 2x8 joist and then drill thru both. The sister joist will take some of the load where the two holes would be in the original joist.
