View Full Version : Seeking: 5' Rectangular Tub w/ Tile Flange, No Apron. Suggestions?
az1324
06-16-2008, 08:21 PM
I'm looking for a 5' Tub for a 3 wall alcove installation. I would like to find a nice modern rectangular shape with as few as possible interior ledges. Also trying to keep the cost down.
I like the Kohler K-1123 (http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Baths&item=11875402&prod_num=1123&section=2&category=10) but they don't offer it with tile flange unless it has the integrated apron and specs say not to install it in an alcove.
I also like the Kohler K-850 (http://www.us.kohler.com/onlinecatalog/detail.jsp?item=461802&section=2&category=10) which says it can be installed in a 3 wall alcove, but seems to use a tiling-in bead for doing so. Also not looking for cast iron and the price is a little higher than I'd like.
The Hydro Systems Lacey (http://www.hydrosystem.com/hydro4/designer/lacey/default.asp) looks great and is available with tile flange, but requires mortar bed setting and price is lower than the K-805 but still a bit high.
I was also considering using the K-1123 with the Schluter®-DILEX-AS (http://www.schluter.com/4_10_dilex_as.aspx) .
But if I can find a nice looking rectangular shaped tub with flange for a good price I would much prefer that route.
Suggestions? Thanks.
jimbo
06-16-2008, 10:18 PM
If you are looking for anything other that a regular 5' tub with front apron, 3 sided tile flange.....then you are in what I call the "foo-foo" category, and get out the checkbook!
