View Full Version : any one know wher to get this PVC fitting? And can I use it like this?
resq944
04-01-2005, 12:11 PM
Edited again :-) See below
04-01-2005, 02:32 PM
http://terrylove.com/images/washer_rough_b.jpg
Washer and Laundry tray waste and vents.
Notice that the vent for the washer angles toward the drain, not toward the p-trap.
Why wouldn't you put a wye fitting on it's back with a street 45 straight up toward the vent? Or like the drawing above it would be a 2x1-1/2" combo.
You can use a santee in the vertical postition like on the left, or if you are going horizontal, you would use a wye fitting for the vent.
Notice that the vents tie back together at 42".
All fittings below the "flood level" of the fixture must be waste fittings.
No "vent" 90 els below or santees on their back, another no-no.
The distance between the vent and the downward bend of the p-trap can be five feet.
04-01-2005, 03:35 PM
Most inspectors would not "buy" any of the three options. If the "Y" were turned around it would work. Without seeing the actual installation and the space constraints, an alternative installation is difficult to suggest. But the one that comes to mind is having the vent come straight down into the 3" horizontal pipe with the tub branch into the side of a tee just above its connection into the 3".
resq944
04-01-2005, 03:54 PM
Edited as per sugestions
King3244
04-02-2005, 01:04 PM
Terry,
On that picture you posted would it be possible to have another sink drain into the upright for the washer drain through a wye?
I am currently in the midst of doing a job that looks almost like that one with the exception of this extra sink. The lady makes wine and this sink would only be used about once a month (not that that makes any difference I suppose). It would be vented properly.
04-02-2005, 04:24 PM
In most areas you could connect it to the washing machine's vent pipe, not the riser for the drain hose. But you could not use a "Y". It would have to be a sanitary tee.
04-02-2005, 06:47 PM
If you want a sink to the right of the washer standpipe, I would add a tee below the tee for the washer drain, and run below to the other side.
Then you would use a long turn 90 el, up to a santee fitting for the sink drain.
The vent above the tee would continue up and could be turned again at 42" and revent with the other vents, or continue straight up through the roof.
As for the top drawing, the wye on the vent, though it looks clean and all, does not meet the purpose of using wye fittings below grade.
The assumption is that water goes down the vents and needs to drain properly through the fittings.
If that is the case, it's obvious that the wye is backwards. The wye should be flipped around and fittings used to bring the pipe toward the wall.
If left as is, the next owner of the home adds plumbing mistakenly to the vent. The waste has to drop down through the wye toward the shower p-trap and then make a U-turn on itself to thead down the drain. Forget about running a snake down that thing.
Your're thinking hard, but not getting it yet.
King3244
04-02-2005, 08:02 PM
HJ, Okay thanks.
I am confused about this wye versus a sanitary tee. In a drain situation wouldn't a wye be better than the sanitary tee?
Terry, I am a different guy posting to the original post.
resq944
04-02-2005, 09:09 PM
I got both the tub and shower done will post pics
04-02-2005, 09:24 PM
That looks better.
resq944
04-02-2005, 09:31 PM
Thanks for all you help terry, So would that be a go IYHO, or rather does that conform to the IPC?
Also can I roll the wye 45deg. so I can get more clearance from the floor.
Clayton
04-02-2005, 10:04 PM
The vent would function great, but no it does not conform to IPC.
No horizontal dry vents allowed from 6" above the flood level rim of the fixture and below.
EDIT: The tub drain, trap, and vent can all be 1-1/2" if that will help, but I would personally keep it 2".
resq944
04-02-2005, 10:29 PM
All the drains and vent but the toilet are in Im almost there:-)
Thansk for all you help guys
